TheEye
I see NEXTBASE has a small battery (Lithium, 3.7v) specifically for Parking mode.
So the way I see it the Dash cam needs the following supply connections 0v, +12v switched from the car (eg cigarette lighter) and Parking mode battery connection.
Q1)Does any have a diagram of how the Parking mode battery is connected to the Dash Cam (either a switch in which case a hole needs to be drilled or another lead that replaces the 0v and +12v feed lead)?
Q2) When in parking mode if the camera gets a shake does RECORD (write to SD Card) eg 10 seconds BEFORE the shake and eg 20 seconds after the shake?
Thanks,
Harry
Thanks,
Harry
