Thanks. I'm on V2.33. My recordings are nowhere near yours. Sharpness and color, your's much better.
Angle of windshield, distance from windshield, how clean windshield is etc. those all affect the picture quality right?
Problem is will the c-lens work with .53? Just for the fun of it I set mine to A lens and night image actually looked pretty good.
I tried to make use of the "Advanced Image Settings" with the more recent firmwares but I was hopeless ( and/or it was). If I remember correctly, any firmware above v0.53 will give noisier images in low light conditions.
Under daylight conditions, the colors do become more saturated with WDR on.
Yes, to a certain extent ( usually reflection/exposure issues ) . In most low light conditions, you can put your Mobius anywhere and I can tell if your Mobius' firmware is > v0.53.
How did you set v0.53 WDR for mode 1 and 2 when it is a global setting in mSetup?Generally, I prefer WDR off w/o daylight. You can make use of the mode1/mode2 setting by having WDR on on one and off on the other.
WDR on in daylight ...
WDR off under street lights ...
Very true indeed - I actually upgraded my factory HID bulbs - first of all I had Osram Xenarc Silverstars and I've currently got Osram Xenarc Cool Blue Intense in.Other light bulbs you can upgrade to high wattage but do so with caution as your factory wires may not handle the extra wattage & will require upgraded harness. And check the law of course as it may be not street legal.
