Panorama II / S - no menu
bobn27613
have a panorama ii s. when i turn on i get the blue welcome screen but no menu or anything else. so is there anything I can do such as a factory reset to reload the firmware etc. I did notice that you can open the unit to pull te battery but that was for a different problem. Help - getting desperate. I didn't do anything that started the problem so I am at a loss what is the issue
Do you also use a gps antenna or not? If yes, check if its inserted into correct port.
thanks but I tried reloading the firmware and same results
