robocop1912
- Feb 1, 2014
I plan the tap into an unused fuse block for a " accessory on" wire to my headliner,and route it to the center headliner near my rear view mirror with quality proper sized wires so I can have the guts of the supplied charger inside a empty sunglass compartment the headliner that is empty..
Thge guts og the charger plug will be their.
Can I just take the fused wired and spilce a nearby ground wire to the wires in the cord leading to the Panorammii
Has anything in the charger conditioning the power or does it just feed it directly to the socket unchanged?
This will allow the power wire to poke under my headliner directly where it is needed
OR can I just run fused wires from empty fuseblock slots, an directy connect it to the wire and save a lot of hassle?
MY kung-fu with wiring is undefeatable! l
TLDR:
doea curcuit boad in the suppied jack and wire do andthing to modulute n=or clean the source to the camera?>
could a wellmade custom cable with proper fuse protection work?
TLDR:
