EricSan
- Dec 28, 2023
- Central PA
This looks like a good setup for dual charging while the engine is running and solar charging when the engine is off. Depending on the ACTUAL current draw when the battery is charging, the 10A fuse may or may not be enough. It's best to measure this with a meter while it is charging so you know the actual charging current. There are some other posts on this forum that indicate recharge rates for parking batteries may be far higher than claimed by the manufacturer. Also, you want to make sure that you are using heavy gauge wire from your car battery to at least the split point for your relays since this single wire will be feeding both recharge circuits. I would recommend a minimum of 14ga wire here. The rest looks good to me.
