ankurthakurofficial
Hello, Regarding the River 2, River 2 Max, River 2 Pro, would their self discharge rates be any different if we are only using USB / 12V outlets?The differences (for our purposes) between the EcoFlow River units is primarily in their battery capacities:
River 2 is 256Wh
River 2 Max is 499Wh
River 2 Pro is 768Wh
For reference, the River2 provides about 40 hours of parking mode for me with a two-camera setup. Given this, I would expect the River 2 Max to be closer to 80hrs and the River 2 Pro to be closer to 120hrs (just going by battery capacity alone). Real differences in run time may vary a bit...
Check their webpage for additional differences (diff number of outlets, etc).
The reason I ask is that I am using Thinkware U3000 dashcam in radar mode and it uses negligible power (~0.2 Watt) during parking mode so the run time of the whole setup is primarily dependent on how quickly the power station discharges itself when left on. I currently use a River 2. If the self discharge rate of River 2 pro is the same as River 2, then it would give me a much longer parking mode time (Weeks). However if due to their "heavier" electronics their self discharge rates are considerably higher, then there would not be any point in upgrading from River 2 to River 2 pro.
