Hello everyone
I recently purchased DR750s 2ch for my 2018 Honda Civic Hatchback.
So my current setting is
-PMP set at 12v + inifinity
-ACC wire connected to Accessory fuse. (with add-a-fuse wire, 15fuse on slot1, original fuse on slot2)
-BATTERY wire connected to one of the constant power fuse. (with add-a-fuse wire, 15fuse on slot1, original fuse on slot2)
Since the cam turns on + works fine when the car is on, I assume the issue is with the constant power source.
I've tried 3 different fuse (I have checked with circuit tester to confirm it lights up when car is off.)
1.Door Lock (20amps)
2.Driver's Power Seat Sliding (20amps)
3.Smart Entry (10amps) / STS (5amps)
They all fail and the cam says powering down. When this happens, PMP is dead and no matter how many times I turn off and on the switch it won't go on, only when I remove the fuse and re-insert then the PMP turns back on.
The only time I was able to have my blackvue work in parking more more than 5hrs is when I removed 15fuse (that came with the kit) from the add-a-fuse slot1 and put the original fuse in the slot1(having nothing inserted on slot 2). This way, it worked well for couple days and now the cam turns off around 5-6hr in parking mode.
Is it the bad PMP? or am I doing something wrong?
