Parking mode Tesla
Finger
Hi
I currently have my a329s connected to my Tesla via an obd usb port. The port stays active when the Tesla sentry mode is active. I use the viofo to supliment Tesla sentry short comings.
I noticed the a329s will enter parking mode after 5mins of no gps or g sensor activity.
Does changing the settings in the viofo affect this. Eg. if I turn off gps, or if I set the gsenor to off in driving mode it won't know to go into parking mode?
Also if I was to buy the Bluetooth remote to manually make it go into parking mode do I need to push the button again when I'm about to drive or will it sense the car moving and return to driving mode?
One other thing. If I manually push the button to enter parking mode will it respect the 90 second timer option in the dashcam or is that setting only for hardwired cams?
Sorry for all the questions but I'm trying to get my head around this?
Hi
An OBDII lacks the 3 wire hardwire kit (Battery, Accessory, and Ground). The car has no way to "Sense" when it's turned on or turned off without the accessory wire. Therefore, the OBDII works because it Always has power. For the camera to enter parking mode, it requires the car to be idle 5 minutes. This is normal behavior. No settings can circumvent how the OBDII operates.
Yes fully understand this but that's not what I asked.
It states it goes into parking mode after 5mins of no gsensor or gps signal, which is perfect but does changing the settings in the dashcam affect this? If I turn off gsensor and gps will it not go into parking mode after 5mins if the car is stationary? Do those settings affect this directly or is the 5min time limit seperate to these settings. Maybe I should have just emailed viofo direct.
No need to apologize this can get confusing.
GPS is NOT used to enable / disable parking mode.
What you're describing is some models have the ability to enable / disable parking mode based on "no activity" from the image sensor.
This method is NOT "reliable" for parking mode.
Reliable parking mode requires ignition based trigger / signal, (like Hardwire cable, or dash cam battery pack).
Since you have a Tesla with no traditional ignition based trigger / signal there are a few ways to do this.
Stay tuned.
-Chuck
@SafeDriveSolutions
@BlackboxMyCar
@CaptureYourAction
@Aussiecams
Stay tuned.
-Chuck
@SafeDriveSolutions
@BlackboxMyCar
@CaptureYourAction
@Aussiecams
Appreciate the reply. Yeah I don't want to tap into a switched wire even though it's straight forward as car is still under warranty. The other option is the 12v in the centre console via a viofo battery pack but as the centre console is sealed I'd have an unsightly cable hanging out the sliding door or drilling through the console side wall to run the cable, neither is what I'd like to do.
It's cool it's working OK for now, even if it doesn't go into parking mode it won't kill my 16v battery because when sentry is running it tops up the 16v. When sentry is off the obd port goes to sleep.
I've ordered the Bluetooth button to initiate parking mode manually rather than waiting the 5min time inactivity activation. I was curious if parking mode would disable after driving off or I'll need to push the button to disable parking mode before driving away, that question I guess I'll be able to answer myself when it comes.
Bluetooth button
Not a fan of the Bluetooth Button, (never have, never will).
Especially for the application you describe.
We have plenty of threads here from customers complaining about Bluetooth pairing loss, and other malfunctions.
One of those gentlemen I tagged may have a better solution.
In my opinion, getting an external battery pack is the best way to go for a Tesla, even if you do not like wires hanging out of the center console. I'm sure one could figure out a way to route or tuck the cable around to be less noticeable.
Thanks guys, I'll run with what I've got and once my warranty runs out I'll go the battery route into the switched power.
parking mode is switched off after you reach about 8kph. I believe it uses the gps signal. Or it's the speed but that would still be from the gps.
Not sure if that is still the case.
Also in older models it didn't always come out of parking mode.
VIOFO dash cams do not use the image sensors to go in and out of parking mode. It should be g-sensor and GPS.
Objection, your honor.
Incorrect.
False & misleading statements.
Move to strike from the record.
It depends on how the camera is powered, (ignition / acc based power supply, or how OP is powering camera).
Please confirm with VIOFO.
Does "IDLE" not correlate to your question? The car remains idle or not moving. Other than 3 wire hardwire kit to trigger the parking mode, it relies on the car not moving. The GPS or G-Sensor has nothing to do with "Idle".
@BlackboxMyCar
His power source is an OBDII Port......
Google states otherwise that's why I asking if the settings in the camera have any effect on this or does it activate regardless.
Anyway I'll wait for support to get back from holiday and follow up with them. Appreciate all the replies.
If the camera is connected to a power source that stays continuously alive when the car is turned off (like a constant-power cigarette lighter socket or a standalone power bank), it monitors its GPS and G-sensor. If it detects absolutely no movement or motion for 5 minutes, it will automatically switch over to parking mode
What you said is exactly what I stated....NO MOVEMENT. I.E. IDLE.
@Chuck McCoy posted a video from Viofo demonstrating exactly what I replied above. There's no GPS enabled in the video. I'm guessing the module wasn't attached. Literally, the unit didn't move / detect movement for 5 minutes and parking mode kicked on with a constant power source (like your OBDII).
Why bother asking something if you want to argue with the correct answer given, and pretend you know better.
interesting to know that VIOFO uses the image sensor to go in and out of parking mode.
Incorrect.
You’re wording / phrasing is doing more harm, than good.
I keep throwing you a lifeline, and you keep tying it around your neck.
It’s in your best interest to choose your wording more wisely.
Young man, (I’m speaking to Michael) you are publicly representing BBMC.
All statements must be 100% true & correct.
You must act above reproach, to not dissolve public trust in BBMC’s long standing excellent reputation.
Alex, and Joseph would not be proud of your last few posts.
-Chuck
Incorrect.
-Chuck
I deleted the posts to avoid any further confusion. To tell you the truth, I'm not at all familiar with the technology behind how some dash cams can automatically switch in and out of parking mode based on perceived vehicle motion due to how unreliable it is. I tried to offer my two cents based on what I've heard here and there about how they work, but I should clearly leave it to the veterans who know more about it, since I'm only familiar with ACC-triggered/3-wire systems.
Unless there's absolutely no other choice, such as the old BlackVues that used the Power Magic Pro which were slightly before my time at the company (I only joined BBMC in 2022, by which point those were discontinued), we as a company only recommend and offer our customers parking mode setups that are triggered by an ACC signal, whether that be through a 3-wire hardwire cable, battery pack, or OBD cable, because it is the only reliable way to send the unit in and out of parking mode.
-Michael
I ain’t no veteran, and I ain't no expert.
I’m just obsessed with VIOFO products.
I started testing dashcams in 2018, out of my own need for one.
I’ve tested every major brand, and most of the "counterfeit crap” on Amazon, and my local Walmart.
VIOFO is the only brand I have a chance at understanding their operation from A-Z because they are the most simple / basic design.
K.I.S.S. (keep it simple stupid).
I’m not like all other testers who have Degrees in computers, electronics, photography, videography, software, coding, etc, and a lifetime of industry experience in those professional / specialized fields of study.
I’m just a failed car mechanic.
Another point of separation from other testers;
I’m not doing this to pay bills, or feed my family.
I have tremendous respect for those guys because they are under the stress of riding a fine line between being called an Influencer / fanboy / shill, and being overly critical to the brands, upsetting them, and having the test unit supply turned off.
I retired in 2015, and I don’t want another job.
Everything I do with dashcams is my funtime hobby.
If it ain’t fun, I ain't doing it.
-Chuck
