what is the environment like though, motion detect on a home CCTV system is nothing like a car system, your home cameras are in a fixed location and only look at a specific scene, you can calibrate a CCTV system to ignore what you want and concentrate on what you want, the system in your car needs to work in any location, the view is ever changing, it won't ever work like your home CCTV system does
I am I expecting too much?
If however, there is no hope of a firmware update to address this, I still think the A119 is a great piece of kit!
It can be mounted on a network of sensors PIR inside the car, to powered dash cam every move, 1 min(more or less).In this way the movement is more effective referral
Of course, motion detection can be adjusted, we have done this in A118C.Jokiin, now we are getting somewhere....I see that 'parking mode' records the event after triggering and not pre event.
However, I assumed that MD mode was the same mode as used in the Aston Martin vid I posted earlier in this thread....
I just thought the A119 would give me the same facility?
I am more than happy with the A119 in every aspect apart from the MD mode....
All I would wish for is an option to adjust the sensitivity of the MD mode, at present, my camera may as well not have MD, and just be set to continuous recording, what ever the res/FPS.... All that some control of sensitivity would allow me to do would be to go straight to the event when reviewing the recording on my PC...should an 'incident' occur, rather than FFW thru 10 hrs footage...
We've certainly requested it, and @viofo said it might be possible and that he'd look into it, but i don't think he's actually said "yes, it's coming".Correct me if I'm wrong but I understand that parking mode is coming with a future firmware update.
TL,DR; motion detection is hard.
If indeed it manages to implement motion detection function, it will have only drawback to detect movement in the visual field of dash cam.Whith a group of PIR sensors can be detected 360grade move around in the car.If person scratch up the car from the back, then motion detection not help anything.Dash cam is new, I have not had time to experiment, but I will come back with concrete results as you will be able to realize practical idea,More info please Doru!
If your car's security system has a bright flashing LED on the dash, it may be constantly triggering the motion detection at night?And during a 10pm till 08am test using MD I had 10 hrs solid, minute after minute, collection of 3 minute files to look thru....(32 Gbs worth)
