PC not recognising SD card
Hoof Hearted
Chorley
I've just had a DR770x 2 channel fitted in my BMW. It appears to be working well. However, when I take out the SD card and put it into my windows 11 pc it is not recognised. Windows says the card is not recognised. This is a problem because I want to be able to use Blackvue Viewer to see my journeys. When I put the card back in the dashcam, all is well and the videos are all there.
This should work, right?
Windows issue, I am sure. Did 11 offer to fix the card?
If you use the disk management tool in 11, does the tool see the microSDXC card?
The above is presuming you have previously formatted the card in the dashcam.
How are you connecting the SD card to the PC? Sometimes it's what you use to connect the card to the PC if it's working fine in the camera. Windows 11 itself doesn't have any trouble with SD cards used in BlackVue cameras.
Very good point. I have an SD card that is not seen when put directly into my Studio. Put it into a multi-slot SONY reader, plug that into the Studio, and the card is seen. I have a Kingston microSDXC card that is particular about card readers also.
