Screen name taken
- Dec 19, 2013
- Spain
- Spain
- 70mai Dash Cam Pro
Having had my camera a few days I have found that it does not always switch off.
First basics.
The camera is brand new and I have used both 32GB class 10 and 4GB SDHC cards. Both have been formatted in the camera. I have two power outlets in the car and I have used both. The cam battery is full to half full. Clips set to 3 mins.
Occasion 1: Using 32GB stopped the car, turned everything but did not lock the car. On restarting the cam took video for another clip then stopped recording. The LCD was still working. No buttons would work so I rest the cam to give me back the functionality.
Occasion 2: Using the 32 GB again all worked well even after a stop. Locked the car but still everything was good.
Occasion 3: I tried the 4Gb card today. I had a slightly different problem to the first time. Stopped the car and locked it . Upon return found the cam not recoding but still had the LCD working and no functionality so I could change the menu turn off etc. I did not have a needle with me this time so let the cam run on it’s own batteries, until empty. Got home, now using the USB cable to hook the cam up to the PC. Now it is charging the batteries and wanted to start recording.
There is a problem but I do not know with what. Is it the cam battery or the power lead to the cam? Or maybe something I have not thought about?
There is one other thing that maybe or may not be part of the problem there is a rattle in the cam. When I press the Mode and Rec buttons this does not happen. Obviously I do not do this when the cam is operational as it may confuse the software. The loose item is clear heard in the sound. But could it be related to this power issue?
First basics.
