cxg2827
I'm about to purchase the PanoramaII, but I'm not too sure about the constant power cable that can be bundled with it. Is this a good option to go with, or would I be better off buying a Blackvue Power Magic?
shutoff voltage : 11.6v, 11.8v, 12.0v, 12.2v. shutoff time : 6h, 12h, 24h, unlimited."
I'm not getting all that... A fully charged (running) car battery may hit 13-14 volts if I'm not mistaken. If you have a power cord that shuts off the device at 12v, where's the problem? Obviously, I'm not an electrical whiz...
Generally speaking there are two different types of lead acid battery, Starting and Deep Cycle. If a starting battery is routinely deep cycled (discharged below 20%-50% of max capacity) it will generally fail after 30-150 cycles. The same starting battery will last for thousands of cycles if it is just used normally (2% - 5% discharge).
If you're planning a more permanent type of installation, you can avoid using your cig outlet completely, leaving it free for other purposes. Check this installation thread for detailed ideas. You just need a female cig outlet adapter and an add-a-circuit or add-a-fuse that plugs directly into your car's fuse box. Most cars have a fuse box inside the cabin so that makes for a very easy installation.My cig lighter is constant on. I'm wondering if there's a way to alter that to only on with ignition on...
I see people have purchased female socket adapters, tie into a circuit that only comes only with ignition. Then, I guess, they use the cig lighter adapter to plug into that. Am I understanding the process correctly?
Yes, that is correct. Once you install the female adapter, it doesn't require any modification of your existing dashcam charger. You can install the female cig outlet in any part of your car, and then just use your dashcam's charger exactly like you would use it with your car's regular cig outlet.
I hid the female adapter and my cam's charger inside the fuse box:
In my case, I decided to wire it to an always-on circuit, but you can tap into a circuit that only comes on with ignition.
They told me they preferred not to install at the fuse box because of errant power draws. They instead will use the female cig outlet and tap into the ignition wires instead.
Do you drive a BMW by any chance?
...depends on which day it is...
What's your point?
Do they have a valid argument or are they just feeding me a line of garbage. Install cost was the same either way so there is no financial incentive for them one way or the other.
Errant power draws...that's probably the reason why they installed it where they did.
Some BMW's have had issues with battery drain. Don't know if it's IBS related or not.
It's actually more work to tap into the ignition wires, but probably more secure. However, since those wires are capable of supplying high currents, they should add a fuse inline with the outlet. Honestly, it's overkill for a typical dashcam and a fuse tap device should cost $5-$10 at the most. The hardest part is probably locating the best fuse location to tap. You'll want to avoid, ABS, SRS, ECU, head/tail lights. Power locks/seats, dome lights or security system may be good candidates. Basically, you want to avoid circuits which prevents the car from moving or causes a safety issue if the fuse blows or the tap vibrates loose.
http://shop.advanceautoparts.com/we...=google&utm_campaign=gpla&utm_content=5170038
KuoH
I think what you are referring to is a problem inherent in what BMW calls the CANBUS system. Not sure about their cars but in their motorcycles, adding an electronic accessory sends this computer (canbus) into a tizzy as it regulates all power draws and doesn't like it.
In this case, the vehicle I installed to isn't canbus driven, but it was a good guess on your part... Thanks.
What I was referring to was BMW's IBS (Intelligent Battery Sensor) that may cut power to a fuse if it finds it's drawing power when it should not be.
CANBUS is not BMW specific and used in many other makes as well. I am using a standard add-a-circuit (fuse tap) in a CANBUS car (not BMW) at the moment without any issues (self installed).
