Pre-Installation Review: Hybrid LiFePO4 + Main AGM Backup for Viofo A329S 3-CH
IgorTa
Dubai
United Arab Emirates
Hello everyone,
I ordered Viofo A329S 3CH + HK6 kit + Energywell P6C. I am about to install a 3-channel system in my Ford Bronco Raptor and would appreciate a technical review of my proposed wiring logic.
The Problem: My daily drive can be only 10 minutes, which is insufficient to fully recharge the battery pack.
The Solution: Gemini helped designed a "Hybrid Power Path" using a 1N5822 Schottky Diode to bridge the car's main 80Ah AGM battery as a secondary backup.
Wiring Logic:
  1. The Viofo HK6 B+ line is connected to both the Battery Pack output and the Car's Main Battery (via the diode).
  2. The LiFePO4 pack (resting @ ~13.1V) will be the primary source.
  3. Once the LiFePO4 pack is depleted, the diode allows the car's main battery to seamlessly take over the load.
  4. The HK6 is set to 12.2V to protect the main AGM battery from deep discharge, especially since it's limited to an 80% SOC by Ford's BMS.
Questions:
  • Will the 1N5822 (3A rated) handle the constant draw of a 3-CH system without overheating?
  • Does the HK6's Bluetooth voltage monitoring handle "source-switching" well, or will it trigger a reboot/error when the voltage shifts from the 13V pack to the 12.5V main battery?
Thanks for the help!
Welcome to DCT, @IgorTa
When two power sources are connected in parallel to a single device, the source with the higher output voltage typically acts as the primary power supply.
However:
- The output voltage of the Energywell P6C is likely unregulated, ranging from 10V to 14.5V, depending on the current battery charge level.
and
- The voltage from a vehicle's alternator+battery can also vary, ranging from 12V to 14.5V.
Thus, these voltage ranges overlap; as a result, the primary power source can be either the vehicle's alternator+battery or the Energywell P6C.
Therefore, you will need not just one, but two diodes—one on each positive lead from each of the power sources.
Note that there will be a voltage drop across the diodes (perhaps around 0.2V).
Therefore, the cutoff voltage on the HK6 must be adjusted accordingly: for instance, if you set the value to 12V, the actual cutoff voltage for the battery will be approximately 12.2V.
This cutoff voltage threshold is necessary to protect the vehicle's battery; however, it is not needed for the Energywell P6C and would merely limit its usable capacity, as that source is capable of discharging down to 10V.
To be honest, I am not a proponent of using diodes and switching between two power sources based solely on voltage differences, as the overlap of the voltage ranges can lead to inconsistent switching.
A more preferable solution would be to use a "Dual Power Transfer Switch"—or, more simply, a UPS (Uninterruptible Power Supply)—devices that we have already discussed here:
To answer your questions:
- Viofo A329S (3ch) may draw up to 10W; consequently, at a voltage of 12V, the current draw does not exceed 0.83 A—thus, a 3A diode should be sufficient.
- Whether or not reboot or errors occur depends entirely on how quickly the power sources switch over.
Viofo dashcams are quite sensitive to momentary interruptions in the power supply. You will have to test to findout.
Finally, I am afraid that with your setup, there is a risk of repeated switching between the two power sources - since, following a cutoff, the battery voltage tends to recover.
However:
and
thank you!! i will order the UPS device and follow your bypass video guide.
@IgorTa
The UPS will not function with your specific setup. I mentioned it to show how the clean switching can be achieved as a reference for a different setup.
Perhaps I should have expressed myself more clearly. (I will edit my previous post accordingly)
In your setup, the UPS's primary input is not controlled by the ACC/ignition signal; consequently, it will remain continuously powered and will never switch over to the vehicle's battery.
Furthermore, once the cutoff voltage threshold is reached, the HK6 unit will shut down the camera regardless.
With the diodes, your configuration may technically work—though not in the manner you envisioned.
In a parking mode, as Energywell P6C voltage will drop to the level of the vehicle's battery, the two sources will begin to "compete/fight".
As I noted in the final sentence of my previous post, this may result in repeated switching back and forth between the two power sources—because, immediately after a switch occurs, the battery voltage tends to recover slightly.
If this scenario plays out, the two power sources will repeatedly toggle between one another, eventually reaching the cutoff voltage threshold basically simultaneously.
It is essential to conduct bench testing to determine whether it is worthwhile to proceed with such a setup.
@IgorTa
Farther evaluating the UPS for your setup, I think you actually can use this UPS, but you will need to fine tune it for your desired UPS cutoff/switching and recovery voltages.
The UPS ships from the factory with preset settings: it switches to the backup power source when the voltage drops to 10V, and reverts to the main power source at 11V.
These voltages correspond to 2.0V at the UVP pin and 2.2V at the Vstart pin (based on 1:5 ratio), which can be adjusted to the required range via corresponding potentiometers.
See attached image for product description.
Operating Principle must be as follows:
The HK6 cutoff voltage must be lower than UPS cutoff/switching voltage which in turn must be lower than the UPS recovery voltage.
For example if HK6 cutoff is set to 12V, set the UPS cutoff to 12.2V and the recovery to 12.5V.
This is necessary to ensure that the HK6 does not shut down prematurely—thereby cutting power to the dashcam—before the UPS has time to switch over to the vehicle's battery.
This video is to show how we can adjust the voltage thresholds for switching from the main power source to the backup source, as well as for the reverse transition—switching back from the backup source to the main source.
