THIS IS INTERESTING..
So I spent a while doing some tests and have come to the conclusion that both the DAB205 and the DEXORS X7 have VERY similar chargers (angle) and produce the same sound. The DAB is VERY noticeable in my test video and in the DEXORS X7 it is there but not AS loud but still can hear it in that charger. In the HP on the other hand (straight), you can NOT hear that sound at all..
Doing the exact same tests with then the BOOSTER pack running the chargers rather than the car produced pretty much no change in sound between the CAR 12Volt and the Booster pack 12Volt.
So whatever the case may be, it appears that the chargers that are used for the DEXORS and the DAB205 is pretty much the same as they produce the same however the DAB205 is MUCH MUCH louder. The problem is that I cannot use the HP charger because it's being sold, to someone and plus #2 the connection is OPPOSITE. It still has the 90degree bend in the connector however it plugs in the OPPOSITE SIDE towards the LEFT side of the camera so that the wire runs along the left side which means it cannot be plugged it with the mount in place since the mount is in the way.
I also replaced the chip with a 16 GIG and had absolutely NO change in the results and so I didn't include in compiled video.
CHARGER SPECS:
DAB205 - 5V 1.5amp (angle)
DEXORS - 5V 1.5amp (angle)
HP F210 - 5V 1amp (Straight)
Perhaps the issue is the extra .05 amp??
