Quality questions
KanBiiru
I purchased my A118-C on Amazon by Spy Tec (made sure) but the videos I've seen looks much better.
I'm not sure if it's the lighting or heat but I feels like my video is much more grainier. It also doesn't help that the A118 jumps around everywhere.
Here's a sample video I just uploaded to YouTube. No edits or other compression to it. Default settings.
Can I get some feed back and opinions if I should return it
what do you mean it jumps around a lot?
YouTube is no place to judge though, it will take your 15mbit file and reencode down to 4mbit max, also never choose the stabilise option (often on by default) when uploading to YouTube
Sorry, was a bit unclear. I meant by the A118 is vibrating against the mount and windshield. I might have to try to secure it with tape so it would stop vibrating so much because you can hear it in the audio.
Outside of youtube, it still looks grainy. It's hard to make out bigger text and overall poorer quality compared to the other videos I saw. It might be lighting but that's the brightest video I could get the past few days.
We can't properly judge the graininess/focus via youtube, but there is are occasional reports of slight heat related focus shift on these. (plastic lens holder/base)
I'd need to see the raw lossless file, you can share one via http://mega.nz
I might see some slight vibration, not sure. If so you should add some pieces of tape/foam on the bracket, to make the camera seat tighter. The curved windshield of some cars can pull on the bracket and create a space after awhile.
something between the mount and camera will stop it rattling
as to the video some full res screenshots will do, preferably something with a lot of other cars around, slow moving traffic, outdoor car park etc, very had to judge on empty highways
In my opinion quality is more or less OKs for highway speed, video quality changes depending on speed and light. I think quality suffers a little bit also because your camera is vibrating too much which is definitely not normal. Not sure if it's a mount or something loose in the camera, or glue it not holding up well. Try to put some tape on mount unless camera sits tight and see if it works better for you.
Yeah, I'm going to tape it or add in some small foam inserts so it would stop vibrating and see if that helps.
The mount is secured and doesn't move too much. I guess that the camera housing is moving slightly or the lense is lightly taping against the windshield.
.....something between the mount and camera will stop it rattling ....
In the past I changed the mount of one of my cams for a generic one which would get a better position and angle on my windscreen. The mount wasn't 100% perfect fit into the cam's slot but I stopped the cam vibrating (which affected video and audio) by using a small amount of blu-tack.
From your first video I'd say the vibration and 'clicking' noise are both caused by the camera not being tight in the mount. I used a few layers (maybe as many as 4 or 5) of blue 'painters' tape on the mounting plate to create a tighter fit in my wife's car and it took care of the problem.
