With a 10A fuse it will operate fine, the only issue is safety. I can't say that it would definitely be safe with a 10A fuse. I wouldn't be too worried about a 5A fuse.
The only problem with a 10A fuse is that if the insulation on the short piece of wire up to the glass fuse gets damaged and starts leaking electricity then that short piece of wire could get very hot and potentially catch fire which could then burn the whole car. With a proper short circuit the fuse would probably blow long before the wire started to smoke but if 9.9A leaks through and that is only 2A wire then it will get hot and it could be dangerous.
The suggestion of tie wrap is just to make sure that the wire doesn't get damaged, either by getting trapped in something or from vibration gradually wearing away the insulation.
An alternative would be to cut that short section very short so that the crimp connector is right next to the fuse and so there is no chance of damage. Then I would be happy to use a 10A fuse if nothing smaller was available.
