BossJustin
- Nov 7, 2018
Just installed 900s 2ch. I'm not sure if I was expecting too much but it seems the camera has a hard time picking up detail. I have checked all the settings:
Recording Settings
-Extreme Recording mode
-Transfer file via H.265 over direct wifi.
-All other settings are factory.
Questions
-Is there an option to switch bitrate that I am missing? Could I have it on a lower setting?
-The card included is a 16GB U1 Blackvue card. Other sub threads seem to indicate I need a U3 for faster write speed?
-Is it possible the focus is just off?
-I am using the blackvue viewer for windows. Could it be that my PC is just too slow/ compression? I tried two different computers however I'll say neither were "brand new"
Install was really easy (including power magic pro), over all the camera works as I expected but the quality on videos from sellers seems much better than what I am seeing. On the linked pictures you can't make out any plate numbers or read what is on the side of the bus.
Thanks in advance for any help! First post however I did plenty of research on DCT prior to buying.
Front Cam
https://drive.google.com/open?id=1ZKFhBiq9hMtgq95pbG8Hv0xdxDMxnO4a
Rear Cam
https://drive.google.com/open?id=1GA69dRJ5Uaj2ytlGBHPU4f70cPS3_Ijj
Recording Settings
Questions
Front Cam
Rear Cam
