Cheechungu
I have a Momento M5 front and rear dash cam system. It is fix mounted to the windshield, behind the rear view but slightly to the left so that I can see the display (barely so, I might add, unless you have telescopic vision). The mount is affixed to the windshield with adhesive and only moves up and down. When I was trying to drive onto a military installation yesterday, the security policeman who checked my ID card told me that I had to take down my dash cam. Since this was not an easy thing to do, I had to pull off to a temporary parking area, disconnect the three cables, and unscrew the camera from the hinged mount. This consisted of a pin that fitted through holes in the hinged mount and the camera itself, then secured with a tightener on the end.
Since this is not an acceptable or quick1 way to comply with the requirement to remove my dash cam, I could really use some ideas on a easily removable mount, something either on the windshield itself, or mounted below the rear view. For perspective, I have attached a front and a side view of the dash cam. Thank you.
