murcod
- Sep 30, 2013
- South Australia
- Australia
- Mobius, A119v2, A119v3
The Mobius refused to start recording with the format done by SD Card Formatter, so I had to use the Mobius in camera quick format and then left it running overnight.
This morning it was sitting there with both LEDs on solid. It ran for 6hrs 45 min, so it appears that it's perhaps getting to the same area of the memory card and failing each time. I'm satisfied now that it's definitely "dead" enough to be binned.
I just checked and it looks like I purchased it back at the end of May 2017. It's in the vehicle that only gets driven about once a week and is parked in a garage- so a very disappointing life span. (I changed to the Samsung EVO cards after having two Sandisk Ultras die, but they both lasted longer than this card.)
It was also in the rear camera which is shaded better (never in direct sun) and runs off the ignition "ON" circuit. Perhaps just bad luck? The front camera has a Lexar 633x 128GB which is about six months older. That Mobius runs for about 15 minutes after the car is locked and is subject to more heat in Summer. It also comes on as soon as the doors are unlocked, so is running a lot more than the back cam. (eg. I might get something out the car but not drive it, or unlock it to give the car's battery a charge if it's sitting for more than 7 days.)
