Tedpro
- Aug 21, 2015
- United Kingdom
"Rear Sensor Not Insert" issue
I have a DR650GW-2CH that has worked fine since late 2014, I upgraded the firmware to version 1.007 and now the rear camera no longer will connect. I have verified that the cause is the firmware upgrade and not anything else like the cable, posting here to see if anyone has come across this and has a fix. There is at least one other person who has the same issue.
I use a 64gb micro SD so that's the card I used to perform the initial upgrade. After determining rear camera was no longer connecting I tried various re-formats and different size SD cards to no avail. I tried to downgrade to version 1.004 trying to borrow from instructions for downgrading a DR400 in this thread but was unsuccessful. Each time I put in an SD card with an earlier version of the firmware I would get an audible "Error 1" message and the unit would fail to boot.
I found my original 16gb SD card that came with my unit and it still had version 1.003 on it. I tried it and much to my surprise it booted and both cameras worked! But this was short lived because on the very next reboot the rear camera again failed to connect. I have not been able to replicate this. I checked the version.bin file on the 16gb card and it showed version 1.007, changing it back to 1.003 and trying to boot from it again did not bring the rear camera back to life.
I checked the log file in *:\BlackVue\System\ and noticed the "Rear Sensor Not Insert" message. I've posted my log below. Notice that initially the unit sees that the firmware version is different (1.003 vs 1.007) but still gets a positive "Rear Sensor Insert" message at [05:08:44], and subsequently the system starts and records both front and rear video as I indicated above. But on the next restart the versions are checked as 1.007 and we get a "Rear Sensor Not Insert" message at [05:11:48] and a "Rear Sensor Fail !!!" message at [05:12:02].
So if anyone knows how to fix this please let me know. Downgrading to 1.004 which I know works would be great as well if anyone has instructions on how to do it from 1.007 on the DR650GW-2CH. All the downgrade instructions I've found in other forums are for other models/firmware versions and haven't worked.
Many thanks.
Code:
[05:08:43]#####[check_version:1725]firmware_version:1.003, FIRMWARE_VERSION:1.007, region: 0
[05:08:43]####[check_version:1730] firmware_version different
[05:08:43][check_version:1743] config.ini is 1.060...
[05:08:44][main:2464] ## Rear Sensor Insert.
[05:08:44][JC:pta_parameter_init:3830] overwrite set >>>> (time)
[05:08:48][BB_COMM_VI_StartTypical:1505] ## Rear Sensor Insert.
[05:08:56]GPS Start
[05:08:56]Start_System
[05:09:06][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_050906_NF.mp4
[05:09:06][JC:pta_file_open:4141] open /mnt/mmc/BlackVue/Record/20150822_050906_NR.mp4
[05:09:06][pta_file_open:4184]EOUT12-2, -1, -1
[05:09:06][recfile_start:811] OPEN FILE 20150822_050906_N
[05:10:07][pta_close:4018]REC FILE CLOSE
[05:10:07][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051007_NF.mp4
[05:10:07][JC:pta_file_open:4141] open /mnt/mmc/BlackVue/Record/20150822_051007_NR.mp4
[05:10:07][pta_file_open:4184]EOUT12-2, -1, -1
[05:10:07][recfile_start:811] OPEN FILE 20150822_051007_N
[05:11:08][pta_close:4018]REC FILE CLOSE
[05:11:08][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051108_NF.mp4
[05:11:08][JC:pta_file_open:4141] open /mnt/mmc/BlackVue/Record/20150822_051108_NR.mp4
[05:11:08][pta_file_open:4184]EOUT12-2, -1, -1
[05:11:08][recfile_start:811] OPEN FILE 20150822_051108_N
[05:11:18]Power OFF 0
[05:11:18][pta_main:2003]OUT3-0[REC END PROC1:0]
[05:11:18]Serial end.
[05:11:18][pta_close:4018]REC FILE CLOSE
[05:11:19][pta_main:2019]OUT3-0[REC END PROC2]
[05:11:19][pta_main:2031]OUT3-1[REC END PROC2]
[05:11:19][pta_main:2058]OUT3-2[REC END PROC2]
[05:11:19][pta_main:2068]OUT3-3[REC END PROC2]
[05:11:19][pta_main:2071]OUT3-4[REC END PROC2]
[05:11:19]End System - 1
[05:11:19]ulEnd1 : 1440216679090
[05:11:19]sync
[05:11:19]Power OFF 1
[05:11:20]End System umount : sync end
[05:11:20]ulEnd2 : 1440216680544
[05:11:20]Power OFF 2
[05:11:22]Power OFF 3
[05:11:23]Power OFF 4
[05:11:24]Power OFF 5
[05:11:47]#####[check_version:1725]firmware_version:1.007, FIRMWARE_VERSION:1.007, region: 0
[05:11:47][check_version:1743] config.ini is 1.060...
[05:11:48][main:2459] ## Rear Sensor Not Insert.
[05:11:48][JC:pta_parameter_init:3830] overwrite set >>>> (time)
[05:11:52][BB_COMM_VI_StartTypical:1500] ## Rear Sensor Not Insert.
[05:11:53]GPS Start
[05:11:53]Start_System
[05:12:02][main:2663] ## Rear Sensor Fail !!!.
[05:12:03][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051203_NF.mp4
[05:12:03][pta_file_open:4184]EOUT12-2, -1, -1
[05:12:03][recfile_start:811] OPEN FILE 20150822_051203_N
[05:13:04][pta_close:4018]REC FILE CLOSE
[05:13:04][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051304_NF.mp4
[05:13:04][pta_file_open:4184]EOUT12-2, -1, -1
[05:13:04][recfile_start:811] OPEN FILE 20150822_051304_N
[05:14:05][pta_close:4018]REC FILE CLOSE
[05:14:05][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051405_NF.mp4
[05:14:05][pta_file_open:4184]EOUT12-2, -1, -1
[05:14:05][recfile_start:811] OPEN FILE 20150822_051405_N
[05:15:06][pta_close:4018]REC FILE CLOSE
[05:15:06][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051506_NF.mp4
[05:15:06][pta_file_open:4184]EOUT12-2, -1, -1
[05:15:06][recfile_start:811] OPEN FILE 20150822_051506_N
[05:15:32]Power OFF 0
[05:15:32][pta_main:2003]OUT3-0[REC END PROC1:0]
[05:15:32]Serial end.
[05:15:32][pta_close:4018]REC FILE CLOSE
[05:15:32][pta_main:2019]OUT3-0[REC END PROC2]
[05:15:32][pta_main:2031]OUT3-1[REC END PROC2]
[05:15:32][pta_main:2058]OUT3-2[REC END PROC2]
[05:15:32][pta_main:2068]OUT3-3[REC END PROC2]
[05:15:32][pta_main:2071]OUT3-4[REC END PROC2]
[05:15:32]End System - 1
[05:15:32]ulEnd1 : 1440216932750
[05:15:32]sync
[05:15:33]Power OFF 1
[05:15:34]Power OFF 2
[05:15:35]Power OFF 3
[05:15:36]End System umount : sync end
[05:15:36]ulEnd2 : 1440216936007
[05:15:37]Power OFF 4
[05:15:38]Power OFF 5
[05:15:56]#####[check_version:1725]firmware_version:1.007, FIRMWARE_VERSION:1.007, region: 0
[05:15:56][check_version:1743] config.ini is 1.060...
[05:15:57][main:2459] ## Rear Sensor Not Insert.
[05:15:57][JC:pta_parameter_init:3830] overwrite set >>>> (time)
[05:16:01][BB_COMM_VI_StartTypical:1500] ## Rear Sensor Not Insert.
[05:16:02]GPS Start
[05:16:02]Start_System
[05:16:11][main:2663] ## Rear Sensor Fail !!!.
[05:16:12][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051612_NF.mp4
[05:16:12][pta_file_open:4184]EOUT12-2, -1, -1
[05:16:12][recfile_start:811] OPEN FILE 20150822_051612_N
[05:17:12][pta_close:4018]REC FILE CLOSE
[05:17:12][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051712_NF.mp4
[05:17:12][pta_file_open:4184]EOUT12-2, -1, -1
[05:17:12][recfile_start:811] OPEN FILE 20150822_051712_N
[05:18:13][pta_close:4018]REC FILE CLOSE
[05:18:13][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051813_NF.mp4
[05:18:13][pta_file_open:4184]EOUT12-2, -1, -1
[05:18:13][recfile_start:811] OPEN FILE 20150822_051813_N
[05:18:13][pta_main:2003]OUT3-0[REC END PROC1:9]
[05:18:14][pta_close:4018]REC FILE CLOSE
[05:18:14]End System - 9
[05:18:14]ulEnd1 : 1440217094151
[05:18:14]sync
[05:18:14]Serial end.
[05:18:14][pta_main:2019]OUT3-0[REC END PROC2]
[05:18:14][pta_main:2031]OUT3-1[REC END PROC2]
[05:18:14][pta_main:2058]OUT3-2[REC END PROC2]
[05:18:14][pta_main:2068]OUT3-3[REC END PROC2]
[05:18:14][pta_main:2071]OUT3-4[REC END PROC2]
[05:18:14]End System umount : sync end
[05:19:15][BB_COMM_VI_StartTypical:1500] ## Rear Sensor Not Insert.
[05:19:16]GPS Start
[05:19:16]Start_System
[05:19:25][main:2663] ## Rear Sensor Fail !!!.
[05:19:26][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_051926_NF.mp4
[05:19:26][pta_file_open:4184]EOUT12-2, -1, -1
[05:19:26][recfile_start:811] OPEN FILE 20150822_051926_N
[05:20:26][pta_close:4018]REC FILE CLOSE
[05:20:26][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_052026_NF.mp4
[05:20:26][pta_file_open:4184]EOUT12-2, -1, -1
[05:20:26][recfile_start:811] OPEN FILE 20150822_052026_N
[05:20:50][pta_main:2003]OUT3-0[REC END PROC1:11]
[05:20:50][pta_close:4018]REC FILE CLOSE
[05:20:50]Serial end.
[05:20:50]End System - 11
[05:20:50]ulEnd1 : 1440242450998
[05:20:50]sync
[05:20:51][pta_main:2019]OUT3-0[REC END PROC2]
[05:20:51][pta_main:2031]OUT3-1[REC END PROC2]
[05:20:51][pta_main:2058]OUT3-2[REC END PROC2]
[05:20:51][pta_main:2068]OUT3-3[REC END PROC2]
[05:20:51][pta_main:2071]OUT3-4[REC END PROC2]
[05:20:54]End System umount : sync end
[05:21:28][BB_COMM_VI_StartTypical:1500] ## Rear Sensor Not Insert.
[05:21:29]GPS Start
[05:21:29]Start_System
[05:21:38][main:2663] ## Rear Sensor Fail !!!.
[05:21:39][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_052139_NF.mp4
[05:21:39][pta_file_open:4184]EOUT12-2, -1, -1
[05:21:39][recfile_start:811] OPEN FILE 20150822_052139_N
[05:22:28][pta_close:4018]REC FILE CLOSE
[05:22:28][JC:pta_file_open:4098] open /mnt/mmc/BlackVue/Record/20150822_052222_EF.mp4
[05:22:28][pta_file_open:4184]EOUT12-2, -1, -1
[05:22:28][recfile_start:811] OPEN FILE 20150822_052222_E
[05:23:02][pta_main:2003]OUT3-0[REC END PROC1:9]
[05:23:02]Serial end.
[05:23:02]End System - 9
[05:23:02]ulEnd1 : 1440242582808
Many thanks.
