Recording Issues
godzilla007
Hey guys!
New here to the forums. Wondering if I could get some help. So my dashcam is connected via USB to my aux port with a car port to USB to the dashcam. Thing is, it'll only record a few seconds then turn off. Any ideas on how I can get it to record properly? I have my settings set to 5 min intervals and for it to loop. It deletes the last video and I'm using a 32 GB SD class 10 card. Any help is appreciated!
Explain your power setup better. Something sounds wonky
I have a car adapter for my 2013 Corolla and from there, its a USB to my Möbius cam. The adapter is just a car port to USB and the USB line leads straight to the cam.
Update: I formatted the card and it seems to be working fine. I think the issue might be that it wont delete the last clip and loop from there. The option is enabled in the mSetup program.
If you press the Mode button while the camera is recording it will set the read-only attribute of at least the current file. I suspect that was the reason the last clip wasn't being deleted. However, I very much doubt this was the reason for your short recordings.
I hope you're using firmware v2.18. It has far less card compatibility issues than previous versions.
I am using the most recent one, I presume it is v2.18. I leave the can mounted so I don't actually press any buttons.
