Two choices.
2. Get your Mobius as close to the glass as you can. This usually requires a custom bracket.
I made a custom bracket which puts my Mobius within 1 mm of the screen glass but I still get dash reflections under some lighting conditions:
Hello!
Sorry if this was addressed before. Sometimes during the day I get a reflection from my dashboard.
Any suggestions on how to fix this?
Thanks for any insight
Hello!
No, not at all. They are custom made for your specific vehicle (year, make, model) the cutouts for vents, sensors etc. are all there.Surely a dashboard cover will cover the screen vents and the audio speakers.
Your window reflections look like mine did before I 'fixed' it. The main culprit is the nice clean and shiny dashboard that is being reflected back onto the window. I bought a black, non-reflective dashboard cover and the problem disappeared. You can do a simple test by covering your dashboard with a black bath towel or sheet and you will see the difference
Unfortunately my reflections are caused by the screen vents and audio speakers so a dashboard cover with cut-outs isn't going to help.
In that case, a polarising filter is your best option. If you have a pair of cinema 3d glasses you can test it out by rotating them in front of your camera. I cut a circle out of one of the lenses and stuck it on my cam.
Hi folks, I know that there are others out there who have done polarisers for the mobius, but I thought I'd show mine, which was made in 6 minutes. It is easily slipped on or off. It can be quickly aligned to provide the maximum effect by a dab of tippex on lens cover and mobius.
I've tried all the solutions. Including sprayon's, lubricants, CPLs and the like.
I've basically went with the most basic one. It's a matter of taste (some do not like the dashmat, even though it looks great on my Audi).
(before / after stills at the end)
