Low Profile– Flexible and invisible. For use up to 158°F.
3M SJ3560 is a clear tape with Acrylic Adhesive, it is for indoor & outdoor , and is UV resistant.
3M Id : 70-0704-2838-1
Specifications indicate it has a 1,000 time open/closure lifecycle before degrading to less than 50% strength.
Setup time on first applying is 24 hours (if i remember right) to reach max attachment strength.
It's most commonly known use is to hold up windshield toll transponders.
pdf with specs , showing SJ3560 in middle column http://www.adhesive.3mil.co.il/?mod=download&table=stories2&field=st_pdf&me_id=235
UPDATE: i found that you can get this from Amazon sellers, just put in.... 3M Dual Lock - SJ3560 1" wide in your Amazon search. Remember that if you get 6 feet, that is only really 3 feet after sticking together. It will run you about $21.00 for 6 one sided feet.
I love this stuff. It holds my Mini 0803 in the rear and my Mini0806 in the front and allows me to swap different cameras easily to test and make notes on them.
(i'd post pictures but imgur seems a little broken at the moment)
