Remove 70mai LOGO and change DATE format.
Hello
on the net I found this for the 70mai
Hi gblpla, thanks for the info... I'll dig and check if works and there're some difference with standard settings of 70mai specially for brightness / contrast and so on... Seems there're a lot of command... šŸ™‚
Hello.
I adapted the configuration of 70mai pro to 70mai.
We already know that 70mai does not have GPS... So, I didn't put that configuration.
I just configured what I think that is compatible to 70mai.
Hello.
Just for information could you share your usercfg file? thanks!
Hi, Thanks.
Sorry, no changes. Still logo and date is on. No mute ... Speaking "start recording" etc.
It must be a method. Maybe file useset.bin is the key. But changing values in the file does no affect.
New model ..... 1s....
Hi ,
About my 7omai 1s - I have tested a way posted in post #10 - link https://dashcamtalk.com/forum/threads/70mai-firmware-update-changing-from-chinese-to-english.33253/
RUZA posted post #10 :
Link that outputs all of camera properties:
http://192.72.1.1/cgi-bin/Config.cgi?action=get&property=*
To set property you need to change "get" to "set" in link and add &value=YYY on end of it. Link should look like this:
http://192.72.1.1/cgi-bin/Config.cgi?action=set&property=XXX&value=YYY
where XXX is property, and YYY is Value.
I can get info about camera parameters, but I can't change any of them. Command set works, with no error, but after listing parameter there is no change. File must be read only ? Any suggestions ?
i found this at the 70mai 1s useset file;
TimeStamp=1 ;0:Time+Logo, 1:Time, 2:Logo, 3:None [Min:0, Max:3]
Put it on 1 (so time only) but logo keeps on being visable
ye i get that but Nothing happends when i change those values. Like i sad its the 70mai 1s version.
And it says 1 time+logo is right?
I have tried changing values at the 70mai 1s useset.bin
So still have problem.
I want to mute my camera and remove logo.
BTW have you test your cameras only in infrared light?
