removed
  • Thread starter Thread starter Deleted member 40186
  • Start date Start date
Ссылка на Регистратор Вьювер я дал.
Тут не в клее дело, надо смотреть видео.
Я вам давал ссылку, что может быть.
Скриншоты сделаны ночью и вечернее время , где сама по себе картинка будет смазываться из-за нехватки выдержки ISO, что бы понять картинку надо дневное видео(оригинал).
That's usually an indication of a dirty windshield.
Could be but I don't like dirty windows so generally keep pretty clean. Had concerns in the past but had convinced myself it was normal. Still photos, not moving, from archive:
1. Center left red light next to left turn sign is an arrow. White lights are street lights.
2. At sundown where blooming begins. Green blooms more than red {Edit: Cannot conclude that based on this picture since the red arrow does not give off as much light as the full green lights}. Experimenting with EV=1.0 at the time. In left turn lane, red signal dead ahead is a red left turn arrow.
3. Dreary day photo. Lights dead ahead and lower left of center have green arrows at the bottom. By zooming I can read the street and speed limit signs across the street.
you have to open the camera up, break the glue seal on the lens so you can rotate the lens, plug the AV out to a TV or monitor, twist the lens to the correct position to get the focus right, seal it up again
search previous threads for the word 'refocus' and you'll find a number of different models, the assembly will differ but the process of focusing is still the same
Пробуйте настраивать, 7-8М, края и центр должны быть резко.
Daytime picture 1080p60 setting is added to first post.
I don't mean to offend but perhaps you're expecting too much out of a small-sensored cam recording in 1080P?
that daytime screenshot that you added looks fine to me. you're driving at speed and the "50" on the upcoming sign it clearly legible. motion blur is absolutely acceptable while you're in motion.
if you take another daytime 1440P screenshot from when you're parked and it's still blurry, then i'll say you have an out of focus camera.
that's a good point. your raw videos should definitely look better than compressed youtube videos.
hope it gets sorted out for you.
