Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
This Mini Q9 dashcam was sent for review.
Thank you @Joy from Skyhigh Electronics.
It's available for purchase at https://www.aliexpress.com/store/product/Arpenkin/1877103_32849434251.html
This dashcam has unique design where the lens is outside the main housing.
This should help heat related focus issues.
After driving an hour, I felt the temperature and the lens was just barely warm vs much warmer housing.
Specifications
*Chip: Mstar 8328p.
*Max Resolution: 2304 x 1296P, 30fps
*Support TF Card Max up to 64GB
*Unique Design with separate lens housing.
*Power cable has built in GPS module
*OBDI power cables
*Hard-wiring cables
PROS: All black, less heat related focus issues due to separate lens housing, OBDI, Hard-Wiring option.
CONS: Proprietary power cable so can't use regular USB outlets.
Mini Q9 Features and Sample Day and Night Videos
Package contents: Mini Q9 Dash Cam with mount, Car Charger, GPS Power Cable, OBDI cable, Hard-Wiring cable, Micro_USB cable, cleaning cloth, wire management tabs and User Manual.
Mini Q9 Dashcam Images:
Mini Q9 Folders, Files and Bit Rate:
Micro SD card has following folders:
Event
Normal
Parking
PLAYER
There is optional rear camera so Event and Normal folders have F and R sub-folders for front and rear videos.
File names have date and time (YYMMDD) so easy to locate a particular file.
Overall bit rate of 2304 x 1296p 30fps video is 16.3 mbps with video @ 16.0 mbps and audio @ 272 kbps.
continued...
Specifications
*Chip: Mstar 8328p.
*OBDI power cables
*Hard-wiring cables
Event
Normal
Parking
PLAYER
continued...
