Lielap
- Jun 24, 2014
- Latvia
- Prestigio RoadRunner 530, Powerucc Panorama II S
1280x720p 30fps
No GPS
2.5" Screen
Med Size: 105x73x27mm
Day: Good
Night: Average
Price: $50
Manufacturer: Prestigio
Country: China
Processor: SQ909B-L
CMOS: ?
Channels: 1
Screen: 2.5"
GPS: No
G-Sensor: No
Wi-Fi: No
Color: Black
Size (mm): 105x73x27
Display Screen: 2.5-inch TFT-LCD screen
External Memory: Support SD card up to 128GB
OSD Language: English, Russian, Latvian, Deutch, Italian, Turkish, Polish, Croatian, Slovenian, Bulgarian, Bosnian
Image Sensor: 1MP CMOS sensor
Diagonal Viewing Angle: 120°
Video Format: AVI
Video Codec: Motion JPEG
Audio Codec: DVI ADPCM audio, Mono, 16000Hz
Video Resolution: 1280*720 pixels, 640*390 pixels
Video Frame Rate: 30fps
File Size: 15min 1.4GB (1280x720@30fps)
Loop Recording: 2 minutes, 5 minutes, 15 minutes
Seamless Loop Recording: 3 seconds of video are lost
Motion Detection: Support
Audio Recording: Support, with built-in microphone for audio recording
Video Output: Support AV out
TV Mode: NTSC, PAL
Frequency: 50Hz, 60Hz
Photo Format: JPG
Night Vision: Support, 4 infrared LEDs for night vision
Auto Power On: Immediately
Auto Power Off: Immediately
Video Output: 1*AV-out
USB Interface: 1*mini USB jack (cannot be used as a power source when recording, only to connect to PC)
Memory Card Slot: 1*TF card slot
Power Interface: 1*DC-in (5V)
Battery Type: Built-in rechargeable lithium battery
Battery Capacity: 800mAh
Battery Life: 2.5h
Release Date: March 2012
Car Charger: Input DC12-24V, Output DC5V, 1.0A
Working Temperature: -35˚C to +70˚C
Energy consumption:
Tested with 13.6V power supply assuming DVR battery fully charged and night recording LEDs off.
1280x720@30fps with LCD on: 110 mA
1280x720@30fps with LCD off: 95 mA
640x390@30fps with LCD on: 90 mA
640x390@30fps with LCD off: 75 mA
not recording LCD on: 90 mA
not recording LCD off: 75 mA
Known problems
The camera has proven to be quite reliable.
Poor sound quality
The dash cam has crackling and hissing sounds when recording. In some cases the quality is so bad that you cannot hear conversations in the car.
LCD always on
There is no timer that turns off LCD automatically. Even by closing the LCD cover the screen stays on. To switch off the LCD the button "down" must be pressed manually.
Parking mode
While the dash cam provides "Motion detection" option in the menu, the feature does not work at all.
Mounting the camera
The suction mount provided is quite convenient. The camera can be screwed and unscrewed very fast. The downside being that the suction mount provided cannot be used to mount the camera to 90 degree vertical windshield.
Sample Videos
Day Video
Disassembling the Dash Cam
