- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
No reports of that
It's to remove the adhesive mount from the windshield.I see in the unboxing video a white string provided, what is for ??
There is no shutdown beep, only a startup beep. Not sure I understand what you mean by "FEATURE recording stops". You can never forget about any dashcam. You should always occasionally check your dash camera footage to make sure everything is working as it should. Never assume it is...on any dash camera.what is this FEATURE recording stops ?? feature they say, this is a bug, from my experience i setup dash cam and forget about it COMPLETY until I need a specific video, let me tel you that even the boot/shutdown beep is a big issue for me, I do not want to hear it each time I turn ignition on/off.
Why would recording stop ??!! does it have the auto loop function ?
I have been living with time for almost a year with GT300 dashcam, I only check the video when there is an accident or something very interesting because I lock the desired video, and get back to watch a week after or more, I mean it is there it will never be overitten.You can never forget about any dashcam. You should always occasionally check your dash camera footage to make sure everything is working as it should. Never assume it is...on any dash camera.
Format warning and beep when recording stops.
That is what I mean by FEATURE, Sunny said it is a very good thingFor the beep when recording stops, it's very good warning so we don't forget it.
when card is full, recording stops ??? where is the auto loop function ??If you watch the video, I stopped the recording but it could stop if the card is bad/full.
Yes, it is a great feature. If camera is not recording it will tell you that it is not recording by flashing the REC LED and alert sounds. When you will hear the alert beeps and see red LED flashing you will look why your camera is not recording.FEATURE, Sunny said it is a very good thing
when card is full up it will start again fron the top and erase each file replacing with a new one and what ever you set for loop it will loop the sameOk if a card has some problem or no card at all, good feature to beep, I thought there is no loop recording if card is full !
thanks, I will probabely buy this cam in the next few days, I am impressed with the quality but still looking if there is no big issues with it 🙂
Registrator Viewer works with the A119 when you use the GPX Extractor program addressed in this thread.
https://dashcamtalk.com/forum/conversations/a119-video-for-gps-data-extraction.8661/#message-40032
RodeoGeorge
Not worth it.My first reply to a thread, I hope I'm doing it correctly.
Great review Sunny! I have one question before I buy.
Did you ever get the A119 ADAS functions to work?
If you did get them to function, at what speed(s) do the FCWS and LDWS begin to function?
Thank You
Heyjohnson
