Until other S&S car owner's experiences, any advices about a good powerbank that I can use in this situation?The "start" part of the cycle may be reducing power to the ciggie lighter temporarily causing the cam to think it's time to turn off. It might also be cutting power to it intentionally during "start" as part of a designed power scheme. This is a known issue with many S&S cars. You may end up needing to use a powerbank for the cam or running a new wire directly to the battery if no suitable circuits are available inside the car.
No. No such thing.Does the A129 not have a power off delay mode built in to the options of the settings? Maybe change the timer within the power off delay setting?
How does it solve the problem of power being lost while the starter motor is operating?get the three wire kit when it comes out, it will solve your problem
I use RAVPower power banks for 2 years, have 3 of them, no issues discovered.Until other S&S car owner's experiences, any advices about a good powerbank that I can use in this situation?
Sent from my 1+ 5T using Tapatalk
It holds power to the camera while accessories is cutHow does it solve the problem of power being lost while the starter motor is operating?
Maybe it has a decent sized capacitor on the input...
It will not.it will solve your problem
The camera's super capacitor should hold it on during engine restart.It will not.
He either has a poor connection to the battery or a very small battery so when it starts voltage drops too much. I bet that lights will also go down to almost half intensity.
Only a power bank will help.
No. No such thing.
This is usually only an option on battery based cameras where the battery can keep it powered for a certain amount of time after the engine is turned off.Does the A129 not have a power off delay mode built in to the options of the settings? Maybe change the timer within the power off delay setting?
RAV, i have one 20k,it can be used same time with charge, but i use wireA out the powerbank....
RavPower sell in NA and UK...
I also found Cellink B (great but highly expensive)
What (I think) I need is a small Powerbank that can be powered and power on the cam in the same time. And to be available in EU... Any thoughts?
