Saar21 said:What is your FW?
Saar21 said:my is LS400W 1305310-SC-2 i hope for you that you dont have this problem because that is not have a pattern is just happen with out a reson.
Saar21 said:I can install your FW on my LS400W it can work?
kooook said:I have Sandisk 32GB Class 10 (30MB/s Max).
However, LS400W stop the video record whenever file size is around 4GB.
I think it was a problem from FAT32 file system of card. I try to format and change to NTFS file system.
Unfortunately, LS400W cannot recognize the NTFS format then I must change into FAT32.
I think that the limitation of FAT32 is only 4GB in a single file.
The single file in a single record cannot bigger than 4GB.
All microSD card brand is the same problem.
Hope DOD will release the new firmware as soon as possible. :evil: :evil:
I mean that DOD should release the new firmware to support NTFS card.jokiin said:This is normal, don't expect any firmware update to come as it won't, not for this anyway
kooook said:I mean that DOD should release the new firmware to support NTFS card.jokiin said:This is normal, don't expect any firmware update to come as it won't, not for this anyway
kooook said:So, now, the word "up to 32GB" is nonsense.![]()
Saar21 said:you have sandisk 32GB class 10 in the LS400W and its not do "Memory Error"?
what is your FW?
and an update the Transcend 32GB microSDHC Class 10 and Samsung microSDHC 32GB Plus Class 10 working ok only SanDisk Ultra 32GB MicroSDHC Class 10 do memory error.
kooook said:In the product specification, it shows "External:Micro SDHC/MMC Card(Up to 32GB)". It cannot be used for real record @1080p @loop record = off.
