ramtsi
And after a few seconds it is going back to normal. Did anyone else encounter this? It happens only when I turn on the camera.
That's worth a shot, here's how
http://dashcamtalk.com/powerucc-panoramaii/#Firmware
From which device you using a micro-usb cable to power up via 5v docket ?After firmware upgrade the issue is solved on 12v startup yet remains when connected via usb.
I guess you using at home unusual micro-usb cable where pins layout allow to activate a factory service mode.A pc... I must say that after the update the green screen showed once in the car as well. Today I'm talking the camera to work so I'll see if this will happen again. Although it doesn't seem to interfere with recording and is only llimited to startup.
Something isnt right. Havnt seen this behaviour before.Better example for what's wrong:
