Chao_Phraya
Good day
Just bought the T130, as you guys recommend it Now I need a 256GB SD card, using it in a hot and humid country. Read about some issues with the SanDisk. Better go for a Samsung then?
In this link:
they recommend the Samsung Pro Endurance. There is only the 128GB version available in my country. As shown in the link the Samsung Evo Plus is not recommended.
However in a anwser from viofo here in the forum
they recommend the red/white Evo Plus.... Which one to purchase?
Kind regards
Chao_Phraya
In this link:
What memory card is recommended for a VIOFO dashcam?
Micro SD Cards play an important role in dashcams, but not all cards are suitable to be used in dashcams. The footage recorded by dash cams is saved on a micro SD card, which is an essential component of the dash cam setup. Here are some parame...
support.viofo.com
Memory Card Size Limitation?
I’ve had no issues using a 256GB Samsung Evo Select (white/green) but decided to get a 612GB Samsung Evo Select (new version, blue). Had it in the T130 for two days - first day was fine, recorded normally. This morning (second day) the dash cam would “start recording” then stops… then start...
dashcamtalk.com
Kind regards
Chao_Phraya
