Eternalblue
Dear all,
it looks like latest Firmware for Q800Pro is having some issues using SanDisk Ultra A1 SDHC cards.
I was using 400GB fine for more than 1 year. As i got some power issues with my Cam which figured out to be my Cellink Neo having some bad soldering which i could fix i did upgrade Firmware to Version q800pro_66_1.02.01.
Once i did insert the card it says SD-Card error occured, Format is required. It says format successful, does a restart and says new FW found and looks like update is succesful.
After restart same error about SD-Card error. So i thought this 400GB card is damaged after recording continiously for over 1 year so i bought 64GB Version of it.
Same problem! Ok, i got another Q800pro from Amazon and could not properly connect to Wlan. So i did upgrade and get same error like above.
Last option i put those SD-card which came with the camera and no error, Wlan working, Camera is good for now.
Might go back to Version 1.01 and see if my other cards are working. I'm going to report back once done.
Cheers,
Cheers,
