I am not sure where to post this on the forum, so I hope it will be OK here
I have a Nextbase 212 dashcam, bought new about 3-4 months ago. Since then, I have had to replaced the SD card four times. The dash cam gives a message about formatting the SD card. This is where the problem comes in.
I try and format the card on the camera, but it will not format. I then try and format the card on the PC, with the same result. I am able to delete the files manually, until the last file, which the PC says is corrupt. The card is then put back into the camera, and I get a message again, saying that the card needs to be formatted. I remove the card, (which has had all files manually deleted) and try and format it again on the PC, only to find that all the files are back on the card.
I have now lost a 16GB Sandisk card, a 32GB Sandisk card, a 64GB Sandisk casrd, and now a 64GB Kingston card. All these cards have had the same issue.
Why would the dash cam go through so many cards.
The dash cam has the R28 firmware installed.
