I'm willing to bet Module 5 and Sunnroof are ACC. I've used the moonroof slot on a few different cars to wire a radar detector so it would turn off with the car. Door Lock is probably constant battery.
Do you have a multimeter? I grabbed the cheapest manual one from the hardware store for 10 bucks to test my fuses before choosing a slot. It made the process way easier. Set the dial on your multimeter to 20V, touch the black prong to bare metal or a screw going into the body of the car for ground, then touch the red to the exposed metal on the top of the fuse (or remove the fuse and put the red prong into the fuse slot). The multimeter should read 12.xx when the fuse slot is receiving power. If it reads 0 with the ignition off and 12.xx with it on, then it should be an ACC slot. If it's getting a 12.xx or non-zero reading with the car off, then it's a constant power slot.
EDIT: Since you have a few unused slots, you should test those first with the multimeter. That way, you can have a slot dedicated to the camera instead of piggybacking off of another slot.
