imgur.com/a/bzORj
Install was relatively simple, hardest part was routing cables from fuse box to glove box. For the camera cable I routed it under the eyesight camera, under the trim along the top, then behind the A pillar cover (I removed it and cable tied the cable to an existing cable) then down through the base of the A pillar to behind the glove box) - looks good, really discrete. I tapped into the 12v ACC fuse for ACC power and the Seat Heater fuse for the Always On power.
No issues with eyesight so far.
I know there are a few vendors on here, so here is some feedback on the unit:
The plugs on the control unit stick out the side which detracts from the sleekness of the unit. I wish they could be plugged into the bottom of the unit with channels to allow you to route the cables in different directions. A base module that could sit on the bottom and plug into the side, with the original cables plugging into the bottom would be a great addition to this unit.
Also a 90' plug would have been nice for the camera connection.
