I search, and dont find anything. Can you help me ?This has been asked and also answered many many times.
Usage: t is2 -shp mode [mode] : Setup mode indicator of sharpening commands
mode: 0 - video
1 - fast still
2 - lowISO still
3 - highISO still
Usage: t is2 -shp [alpha|fir|spat|cor|sig_retain|level_min|level_all]
: get the sharpening filter settings of specified modes
t is2 -shp max_change [max_chg_up] [max_chg_down]
: set sharpening max change setting
t is2 -shp fir [str] ([coef0] .. [coef5])
: set sharpening fir setting
t is2 -shp fir-2 get [Path]
: get sharpening fir setting(for strength = -2)
t is2 -shp fir-2 set [Path]
: set sharpening fir setting(for strength = -2)
t is2 -shp spat [mode] [iso_str] [dir_str] [edge_thresh] [max_change] [wide_edge_detect] [adaptation]
level_str_adj [not_T0T1_level_based] [high] [high_delta] [high_strength] [low] [low_delta] [low_strength] [mid_strength]
: set sharpening spatial filter setting
t is2 -shp dir_shp [enable]
: set directional sharpening
t is2 -shp dir_shp dir_str [dir0]...[dir8]
: set dir_strength of directional sharpening
t is2 -shp dir_shp iso_str [dir0]...[dir8]
: set iso_strength of directional sharpening
t is2 -shp dir_shp dir_amt [dir0]...[dir8]
: set dir_amounts of directional sharpening
t is2 -shp cor [coring_path]
: set sharpening coring table setting by reading text based file
t is2 -shp sig_retain [str]
: set sharpening signal retain level strength
t is2 -shp level_min [low] [low_delta] [low_strength] [mid_strength] [high] [high_delta] [high_strength]
: set level control for minimum sharpness
t is2 -shp level_all [low] [low_delta] [low_strength] [mid_strength] [high] [high_delta] [high_strength]
: set level control for overall sharpness
t is2 -shp smooth [select] : Test DE smoothing
select: 2 -low smooth
select: 3 -mid smooth
select: 4 -high smooth
t is2 -shp dir_shp disable
t is2 -shp dir_shp dir_str dir0
t is2 -shp dir_shp dir0
t is2 -shp fir coef0
t is2 -shp spat 0 100 0 0 0 0 0
t is2 -shp 0 0 0 0 100 0 0
I can not find too This command i find in disassembled firmware.I can not find anything on sharpness for the sj5000plus.
Yes, i tried these variants:do you have any example scripts?
t is2 -shp mode 0
t is2 -shp fir 100 0 0 0 0 0 0
t is2 -shp max_change 5 5
t is2 -shp mode 0
t is2 -shp fir 46000 0 0 0 0 0 0
where coring.txt has the following contents:t is2 -shp cor d:\coring.txt
104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 92 84 72 60 52 48 40 40 32 28 104 104 28 32 40 48 60 68 76 84 96 100 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104
#disable sharpening
t is2 -shp mode 0
It removes all fake detail.
these are the three lines in my ash for sharpening:
they only work with coring.txt that is full of numbers 8-10. I use 10 right now.
I attached samples for coring 50 and coring 8 (always 256 times the same number in the txt)
I also attached my coring file.
With both. It is only necessary to substitute the appropriate option in the t -shp mode at the beginning of the script:its work for videos or pictures?
mode:
0 - video
1 - fast still
2 - lowISO still
3 - highISO still
can i put all options in a script? hahaWith both. It is only necessary to substitute the appropriate option in the t -shp mode at the beginning of the script:
Code:mode: 0 - video 1 - fast still 2 - lowISO still 3 - highISO still
No its not fake detail you just dont understand how it worksyes it is fake details.
