Erebus
- Jun 15, 2015
- Greece
- Xiaomi Yi
@fuyghjb is it possible to have the coring script in combination with the high bitrate script? I have tried this with no luck (in bitrate):
Code:
sleep 5
t is2 -shp mode 0
echo --- CORING SETTINGS: > d:\shp_cmd.txt
t is2 -shp cor >> d:\shp_cmd.txt
echo >> d:\shp_cmd.txt
echo --- SIG RETAIN: >> d:\shp_cmd.txt
t is2 -shp sig_retain >> d:\shp_cmd.txt
echo --- LEVEL MIN: >> d:\shp_cmd.txt
t is2 -shp level_min >> d:\shp_cmd.txt
echo --- LEVEL ALL: >> d:\shp_cmd.txt
t is2 -shp level_all >> d:\shp_cmd.txt
echo --- FIR SETTING: >> d:\shp_cmd.txt
t is2 -shp fir >> d:\shp_cmd.txt
echo --- MAX CHANGE: >> d:\shp_cmd.txt
t is2 -shp max_change >> d:\shp_cmd.txt
sleep 10
echo --- SET NEW CORING --- >> d:\shp_cmd.txt
t is2 -shp cor d:\coring.txt
echo --- CORING SETTINGS: >> d:\shp_cmd.txt
Sleep 15
#enable raw+jpeg stills
t app test debug_dump 14
#set noise reduction value to 3072 (nightmode)
#t ia2 -adj tidx -1 3072 -1
#set noise reduction value to 1536
t ia2 -adj tidx -1 1536 -1
#Set Res720p120 at 30mbps
writeb 0xC06CC426 0x34
writew 0xC05C2812 0x41F0
#enable 1080p30 at 30Mbps video
writeb 0xC06CC426 0x06
writew 0xC05C1F72 0x41F0
#enable 1296p30 at 30Mbps video
writeb 0xC06CC426 0x02
writew 0xC05C1EB2 0x41F0
