Hi zinm, I 've extended the coupon code expired date to the end of April![]()
Thanks. Got one. Much appreciated.
YesWas the 25 and 25.5 too small?
I have just ordered the M10...
Welcome to DCT. The M10 is not suitable for such use in your climate. A capacitor-based dashcam is needed. What's your budget?Is M10 suitable to be use as a dash cam? I was wondering if it could stand the high heat in the car and long recording hours 12 hrs daily? My daily temperature is about 31 degress celsius.
The M10's manual states several times that if connected to an external power supply the camera can be operated without the battery.Is M10 suitable to be use as a dash cam? I was wondering if it could stand the high heat in the car and long recording hours 12 hrs daily? My daily temperature is about 31 degress celsius.
if the WiFi is only a few bucks more, it definitely comes in handy to make the camera even more versatile. I used it to set the camera up outside as a make shift security cam with my tablet as the monitor. The battery on the SJ lasted 1 hour in WiFi broadcast mode. The range was decent for a small camera, you could view at the edge of range, just not remote record. It's also nice when chest or helmet mounting it, so you can aim it perfectly.
Are you testing with "car mode" function? I am wondering if M10 does not have battery in it, does it save correctly in all modes?Ok I just did some more tests, including a longer 3, 3 min clip save and no problems. I notice the blue led on the top blinks blue and yellow rather than just blue, the settings Were unchanged and all clips were all saved. My tests consisted of plugging the USB power cable into the M10, letting it auto record then pulling out the cable to end recording.
