On my mac I had success formating my 2TB Samsung T5 using Samsung Magician (free tool from Samsung for their SSDs). I set it to exFAT/MBR and it worked fine; I was able to format the drive again with the dashcam as well. I had previously tried exFAT/GPT and got an error and the A329 said the disk was full and couldn't reformat the drive.Can you post the command you used to format the drive? Thanks
I'm trying to do it on a Mac, but the camera just wont recognize it no matter how I format it or not format it. I used the following to "just create a partition"
diskutil partitionDisk /dev/disk2 GPT "Free Space" "" 100%
hi Blinkenjim, I have samsung 990 pro 4TB and 2m belkin C to C cable, i did creat gpt and 1 partition and let Viofo format the drive, connect successfully but it’s really unstable. Which enclosure model and cable are you using? Can you try to test with short type c to c cable included with device?Background: I'm primarily a Linux/Mac user, and I know very little about Windows. However, I am and engineer and software developer so I'm familiar with file systems and external drives, etc.
I have a new A329 and a 4 TB SSD in an external enclosure that I'd like to use with it. I'm confused by the apparent contradiction: (a) Viofo says the A329 supports external SSDs up to 4 TB, but (b) the A329 will only support MBR formatted drives. The contradiction is that MBR only supports partitions of up to 2 TB (correct me if I'm wrong, please); GPT is required for larger partitions.
On the other hand, I've read that the limitation is not inherent in the on-disk data structures, but in the software often used to format them. However, every Linux (I'm on Ubuntu 24) app I've tried enforces the 2 TB limit.
I have tried using a program called GUIformat, running in CrossOver/wine, but it doesn't see the drives -- I get an empty list (yes, I've configured drive mappings in the wine settings).
So here's the big question: is it even possible to format an MBR drive with 4 TB partitions? If so, how?
Or is there a workaround -- can the A329 use two 2T partitions if I format the disk that way?
Would appreciate some help.
How is it unstable?I use a Samsung 970 EVO M2 SSD for 250 GB with a case for these disks and the cable that was included and everything is super!!but it’s really unstable. Which enclosure model and cable are you using?
I am turn on the A329 take 5 min and waiting foreverHow is it unstable?I use a Samsung 970 EVO M2 SSD for 250 GB with a case for these disks and the cable that was included and everything is super!!
That's exactly how I use it!!Can you check which cable SSD do are you using ? Can you test with short USB-C cable included in A329 box?
Ubuntu has exfat support as well, but you have to install the exfatprogs package.Ubuntu appears to refer to "ExFat" as "Vfat". If I format a disk with mkfs.vfat, I can then use that disk anywhere an "ExFat" disk is required.
