donburi
- Apr 1, 2021
- Honshu
- Japan
- Comtec ZDR035(Front & Rear) Viofo A229 Pro(Front Only)
(I am using machine translation, sorry if the question was rude)
Issues:
The color changes are too drastic. It suddenly turns yellow-green, then orange. The actual color is significantly different, and it’s clear that the A129Pro looks better when compared.
The exposure adjustment is not working well, and the image can suddenly become a bit too bright after appearing dark.
The sound quality is too poor. I think this is due to the bitrate being only 64Kbps and the sampling rate being only 16KHz. (A129Pro is 96Kbps, 32KHz)
Requests:
I would like you to add the H265 codec. Despite being equipped with 4K and even HDR, I think it’s a waste that only the H265 codec is missing, and personally, I’m a little dissatisfied with the H264 video, and there have actually been situations where the letters on the license plate of an oncoming car were distorted and unreadable. I hope that the H265 codec will be added in a future firmware update.
(All of the following are based on the assumption that they will be implemented on one channel)
I think the A229Pro uses a better chipset than the A129Pro, but the A129Pro was able to achieve a bitrate of 60Mbps with the H264 codec. I think that the A229Pro, which uses a chipset with higher processing capabilities, should be able to achieve a higher bitrate than the A129Pro (for example, 70Mbps or more). If there is room to increase the bitrate, I would like you to do so.
This is a bit different, but in the A119 mini series, A139, and A229Plus, they are achieving 60FPS at 2.5K with a slightly insufficient bitrate. I think that with the same bitrate as when running at 4K30FPS (or slightly lower), it should be possible to run at 4K60FPS without increasing the load too much on the A229Pro as well. Is it really impossible in terms of performance? (I understand that there is a possibility that the image may be disturbed due to insufficient bitrate)
I would like you to add a 2.5K60FPS mode.
If a 2.5K60FPS mode is added, I would like you to make HDR available.
To give an example of my request:
4K 30FPS H264:70Mbps H265:60Mbps(or more)
4K 30FPS HDR H264:70Mbps H265:60Mbps(or more)
4K 60FPS H264:70Mbps H265:60Mbps(or less)
2.5K 60FPS H264:70Mbps H265:60Mbps(or less)
2.5K 60FPS HDR H264:70Mbps H265:60Mbps(or less)
Regarding the issues, I’m struggling to understand why Viofo released it in such an unfinished state. As for my requests, I understand that it’s not as simple as it sounds, but if it’s possible, I would really like you to implement it, which is why I created this thread.
I hope at least my issues reach Viofo.lol
Issues:
Requests:
