Thank for that. I laready have the dashcam hard wired in with 2 cables. (one to a switched live in the fuse box and one to earth). When the stop/start activates, I am sure the switched live remains on (the radio doesnt stop).
I have the same issue in a car without stop/start, if I put ignition on, but wait about 5 secs, before starting the engine.
I was once told be a previous manufacturer " When you turn the engine on , the voltage across the car charger will be lower and the camera will switch off automatically like you turn off the car.
Therefore, if you turn on the ignition and start the engine immediately, the camera will switch on normally.
Otherwise, the camera will switch off because the system will mistakenly believe that you are off the car."
So it appears that once allowed to fully boot up, if you then start the car, the drop in voltage makes the camera think you have turned the car off, so it shuts down. It never gets another signal to boot it up again, even though its receiveing the switched live.
@viofo @VIOFO-Support -- Is that correct, and was it only an issue with the old A118 or also the A119 series
