Techmoan Review
russ331
Kingston on Thames
Mobius B (x2) & A119
Techmoan has reviewed the A118 / B40...
Haven't had time to watch it yet, but thought you'd like to be aware of it.
i noticed his has the new vents, and also has a place for your numberplate or whatever name you want to put in - firmware 20140814. also in the youtube clips (didn't download his raw clips), i didn't see the repeated frame about a second into the next clip like chris has identified and i've also seen in mine. wonder if that's fixed in this firmware...
I think there was a repeated frame where he talked about overlapping clips.
There's a different problem though, Techmoan's unit has a bug in EV metering routine similar to cheaper Novatek 96620 chip "default" behaviour - the whole image goes dark if there's a section of bright lit sky in the frame. Older firmware in my A118 doesn't have it, in fact I haven't seen it in any 96650 chipset based dashcams yet.
Just wondering what the situation is with these cameras regarding genuine/fake models?
Looking on ebay and prices seem to range from £30 up to £50 - most units seem to be around the £40 mark - although someone selling fakes might be more likely to sell at the average price?
Sticking to the vendors that post around here is a safe bet.
FoxOffer
Pier28
I might be missing some others.
I got mine from FoxOffer1 on ebay, no complaints. These vendors also try harder to keep up with firmware updates and are likely to help you out if you have problems.
I just ordered one after viewing Techmoan's review.
It's going to replace my 0801. My Mazda CX-5 has a huge sensor cover in the middle of the windshield so it's hard to find a dashcam that can fit properly around it or on it.
The 0801 is very loose from the heat and if I don't check it once in a while, it'll fall off.
Not getting the GPS module, didn't give me any advantage with the 0801.
If I like this A118, I'll order the updated one when it comes out and use that for the front, and the old version for rear of car.
The Street Guardian SG7LA50G will be a good option in this same category soon as well.
FoxOffer
Pier28
got mine from spytec via ebay. i haven't cracked it open, but i have no reason to suspect it's a fake.
I had A118 with the same firmware as Techmoan and the same problems: reflections and dark picture when bright light goes directly in the lenses...
I managed to fix both. Reflections completely gone by using polarizing filter which I created from 3D glasses.
I think this is the best solution for that camera because no round glass filter could be installed with the camera... So I cut rectangular shape piece of plastic from 3D glasses and installed on top of lenses using 2 small pieces of 3M tape. The very important thing is the correct orientation of the filter when cutting to preserve polarization effect! As the result the reflection completely disappeared.
Regarding dark picture solution. I set HDR OFF and EV= 0 (zero). Now the camera works great.
