Tele.photo lens
Have a a329s, can I install a telephoto lens using the same cable as the inside camera? And just swap back and forth between the two cameras if I want to?both mounted on the front window
Why don’t you install both?
If you don’t want one camera to record at times you can change that in settings.
The Coax connectors are not meant for constant plugging / unplugging.
The connectors may wear out over time.
-Chuck
I added the Telephoto to my A329S 2-channel (thank you Matt at Seattle Dashcam). Had to update to the A329T firmware to get the Telephoto recognized in the settings. Works great.
Thanks , did you have to just upload a329T, I’ve already uploaded the new firmware on my camera?
Yes that helps thanks, will have to try that,
Also can you do all that on an iPad? Don’t have a laptop .
Thanks did that on my iPad seems to be working 👍did it on a test Sd card , so if I messed it up I would still have my good one,
Thanks again
