murcod
- Sep 30, 2013
- South Australia
- Australia
- Mobius, A119v2, A119v3
But don't other dash cams use Li-ion batteries too?
99% of themBut don't other dash cams use Li-ion batteries too?
Had a daft idea.
Using an extension lens, what if the mobius was mounted to the roof itself?
Pull back / cut a flap in the roof lining, sand back a bit of paint on the underside of the roof to expose bare metal & mount the mobius directly to the bare metal ensuring the mobius' heatsink is making good contact with the roof.
Maybe build a dual LM7805 regulator circuit? An LM7805 regulator IC would provide the required power for either the fan or the camera, but not both. At 1A available current, it falls short by the 230Ma the fan requires to run including 1amp specified for the camera. Mobius data specifies "1A when charging".
The 1A is recommended by the developer. When recording and charging at the same time the Mobius may draw over 600mA. The figures measured by myself and others are average values. Peak values can be higher.I have seen this qoute time and time again...Mobius data specifies "1A when charging".
Why?
On the very first page of the RC tread a fella by the name of Haku took these measurements..
No battery connected• Standby mode: 225mA @ 4.97v
• Standby mode with AV-Out enabled: 265mA @ 4.97v
• Recording 1080p: 305mA @ 4.97v
• Recording 1080p with AV-OUT enabled: 330mA @ 4.96v
Battery connected
• Battery being charged from flat, powered off: 186mA @ 4.97v
• Battery being charged from flat, recording 1080p: average 505mA @ 4.95v
So, with Vid out on we can assume another 40ma or so..from the above measurements
So the max possible current draw with it all ON would around 550ma
even if you add a 260ma fan..your still at 800 or so ma...under the 1A limit of both the USB charger cig plug..and a 7805 1a version..there is a 1.5A version as well.
Which is why I pointed to that fan in post 82# It runs on 160MA..and is smaller as well
Is there some technical reason that I do not understand?
You will most likely get away with a high quality charger with a slightly lower spec., but why take the risk?
....get away with a high quality charger with a slightly lower spec., but why take the risk?
It's much better to power the Mobius with external USB power. The camera was specifically designed to be powered with external USB power with or without the battery installed!But why take the risk?
Because, I'm just not right in the head. There is something just plain wrong with me
I tend to take one gadget..combine it with a 2nd gadget..and make something to fill a specific use.
This is one of those things. Here is the plan..
Mobius 24/7 Dashcam and Mobile Security Camera mounted in truck.
Mobius + Fan + RX mitter.
I agree normal dash camers don't need a fan a heat sink upgrade should be fine.
I accept that I will..the RX unit gets hot too!
Everything is all built and working.....on the bench, no internal batttery
So my last question to ISO is would I be better off powering the camera through the stock battery plug..or through the mini usb?
Does powering throught the mini usb..engage the charging circuitry..even with no battery present?
Maybe he has more important things to do. Sorry, but I really don't know.What is the hold up with the supercap Isoprop?
Let the number talk will be more exactly. Different people might have different feeling about the warm/hot.I've been using mine in the car all day 6 hours at least and yes it gets warm but not overly, just got warm not hot !
Do you know it's an over heating issue for certain? Does the case - or some other part - show signs of excess heat?Well it's happened !the camera went into full melt down and no longer works! So a refund will now be asked for !
