probably a silly question ! But how do you guys power up the f750 when on your p/c or mac ? Is there a power lead you can purchase with a usb connector one end ? If so do thinkware sell them ?
I don't know if its just the UK model, but my F750 has no data connector. When I want to use the Dashcam Viewer I have to remove the SD card and put it into my PC's SD card reader. Are you guys actually removing the camera unit from the car in order to connect it to a PC?
i sometimes download with my phone & sometimes i take the card out.
it's true, that download by phone is rather slow ( especially compaired to my previous blackvu camera),
but in order to take the card out i have to unhook the camera, so it's both not "ideal"..
I,m just wondering do you have to have the hard wire kit to use the parking mode function or as long as i have power at my cigarette lighter will it work ? i,m assuming it won't as it needs to feeds and what setting's do you use
Thanks
Yes, the only way to enable parking mode is with the hardwire kit. Otherwise operation depends on how the car supplies the auxiliary socket (cigarette lighter). If it is permanently powered then the camera will keep running in continuous mode unless you manually turn it off. If the car removes 12V from the socket when the car is parked then the camera will just turn off.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
