Hello DashCamTalk community. I need help hardwiring my new Thinkware U3000 dashcam along with the Ivolt Xtra into my Audi RS5 b8.5.
I am following the Thinkware diagram as shown in the photos.
I'm planning on using a fuse tap to plug the B+ (Constant power) into the trunk 12-volt socket/cigarette lighter fuse. The thing I don't understand is when I use a circuit tester on the 12-volt socket/cigarette lighter fuse, its lighting up showing constant power even when my car is off.
I tested both 12-volt socket, cigarette lighter in my car (one in the front centre console and the other in the armrest storage) when the car is off and both 12-volt sockets seem to be off.
Does anyone knows what is happening here and if this is a fuse I should be using? The reason I want to use this fuse box in the trunk for constant power is because I am putting the Ivolt Xtra in the trunk and the fuse box will be right next to it and its a 20 amp fuse which matches the 20 amp fuse that was included in the Thinkware Ivolt Xtra kit.
I am planning on wiring the ACC wire to the right passenger side fuse box and using the MMI/Radio fuse. The fuse currently in that slot is a ATO 5 amp fuse so i'll need to buy another 5 amp fuse for the ACC power fuse tap. The reason I am planning to run ACC to the front passenger side fuse box is because all the fuses in the trunk light up with using a circuit tester so they appear to be B+ (Constant power).
Does this look correct? Any advice would be greatly appreciated. Attached are images of what I am looking at.
![Screen Shot 2023-12-07 at 13.52.24.png Screen Shot 2023-12-07 at 13.52.24.png](https://dashcamtalk.com/forum/data/attachments/69/69449-2f920f18af8fb72efa5618f94d10d917.jpg?hash=L5IPGK-Pty)
![Screen Shot 2023-12-07 at 13.52.37.png Screen Shot 2023-12-07 at 13.52.37.png](https://dashcamtalk.com/forum/data/attachments/69/69450-2c36a719f6eac14b82d986a72a493f8b.jpg?hash=LDanGfbqwU)
![photo_2023-12-06 14.11.28.jpeg photo_2023-12-06 14.11.28.jpeg](https://dashcamtalk.com/forum/data/attachments/69/69451-618e00da37b7b26ddb5d36411ad3fb51.jpg?hash=YY4A2je3sm)
![photo_2023-12-06 14.11.32.jpeg photo_2023-12-06 14.11.32.jpeg](https://dashcamtalk.com/forum/data/attachments/69/69452-97b5a9a84771a2c36593bfcc31bc4f77.jpg?hash=l7WpqEdxos)
![Screen Shot 2023-12-07 at 13.53.53.png Screen Shot 2023-12-07 at 13.53.53.png](https://dashcamtalk.com/forum/data/attachments/69/69453-b06d1075c148db66ba79e0e517810776.jpg?hash=sG0QdcFI22)
![Screen Shot 2023-12-07 at 13.53.59.png Screen Shot 2023-12-07 at 13.53.59.png](https://dashcamtalk.com/forum/data/attachments/69/69454-074be503bffb6d1b5b17114a89689ce4.jpg?hash=B0vlA7_7bR)
![Screen Shot 2023-12-07 at 13.54.05.png Screen Shot 2023-12-07 at 13.54.05.png](https://dashcamtalk.com/forum/data/attachments/69/69455-56ffd586860840cea60c5b93057b8792.jpg?hash=Vv_VhoYIQM)
![Screen Shot 2023-12-07 at 13.54.10.png Screen Shot 2023-12-07 at 13.54.10.png](https://dashcamtalk.com/forum/data/attachments/69/69456-6992cf51f25a11f86d69465cbb39207d.jpg?hash=aZLPUfJaEf)
