rcg530
- Jan 23, 2021
- California
- BlackVue, Thinkware, VIOFO, Vantrue, Blueskysea, FineVu
I've been testing the Thinkware OBD-II power cable (TOC-300). The information received from Thinkware was quite vague. The only thing my Thinkware contact stated was that it used OBD-II data link connector pins 4/5 (ground) and pin 16 (vehicle battery power). Thinkware has stated that the manner in which the TOC-300 operates is propriety information. I do not agree in that the user of the TOC-300 needs to know at least a general description of how it operates to know whether it has a chance of working in their vehicle. Older vehicles don't have CANBUS networks, so if it uses CANBUS activity to know when to turn on/off the ACC power to the dash camera, that could be an issue.
I ran tests with the TOC-300 not plugged into an actual car. I have a data link connector with a 16 wire pigtail that I wired up to provide power to pin 16 and ground to pins 4/5. I used that to test the TOC-300 to see if the TOC-300 would turn on/off the ACC power to the dash camera based on the voltage level on pin 16. It does. Voltage levels (increasing) over 13.4 volts will have the TOC-300 turn on the ACC power. Voltage levels (decreasing) at or below 12.95 volts will have the TOC-300 turn off the ACC power to the dash camera. The 12.95 voltage level is a concern for some cars like mine that use an intelligent voltage monitor to determine what voltage level the alternator should output based on the charge level of the vehicle's battery and the current load on the electrical system (monitors with an amp clamp device around the negative battery cable).
I installed the TOC-300 into my car and I found the TOC-300 will turn on the ACC power to the dash camera when there is CANBUS activity present on pins 6/14. The TOC-300 will turn off the ACC power to the dash camera about 10 seconds after the CANBUS activity stops. The U3000 will enter parking mode 30 seconds after the TOC-300 turns off the ACC power. I've observed that when I open/close my car's door/trunk, that will awaken one or more modules connected to the CANBUS which results in the TOC-300 turning the ACC power on for the dash camera which makes it exit parking mode. After the door/trunk is closed and the module(s) on the CANBUS go back to sleep, the TOC-300 will turn off the ACC power to the dash camera which allows it to re-enter parking mode.
I'm still trying to get a better definition of how the TOC-300 operates from Thinkware. For example, if the vehicle it is installed into does not have a CANBUS network (early 2000s model years and older) how will it operate?
I created two videos showing my voltage level testing (not in a car) and the second one with the TOC-300 in my car. The video showing the testing in the car is where I use a data link connector breakout box to monitor/show the CANBUS signals on pins 6/14. The voltage level testing video was created with the "false" impression of that the TOC-300 only used the voltage level present on pin 16 of the data link connector.
