It is a pity that the current dash cam solution provider has no plans to provide an obviously low-power solution in the short term. Maybe people are more concerned about the quality of video recorded while driving, so the competition is concentrated in these aspects.
The Starvis 2 is advertised as having %30 less power consumption, the average analog voltage is 3.3 vdc. The problem is not the dashcam, the sensor, the GPS or parking mode, the problem is the car battery is not up to supplying reliable, long term power to the camera if you want parking mode. It is unlikely we will see, in my lifetime anyway, a dashcam that will run for weeks in parking mode on the average car battery. I recently replaced my stock, average performing Subaru battery with an Odyssey Group 24 dual purpose AGM battery due to accessory use. It will last longer in parking mode than the stock battery, but no much longer.
No doubt consumers want the best image quality possible, I know that I do, as do most others. That of course, with current technologies, drives a higher power usage than a camera that produces a 640x480 image.
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
At some point it will not matter as it is a good bet that at some point in the future, all new EV cars will come with multiple dashcams that are powered from the main cells.
My car, has an aftermarket Remote Start system (installed by Best Buy in early 2016). Compustar with a DroneMobile add on. (and a aftermarket stereo headunit)
That DroneMobile Cellular module, was the cause of significant parasitic drain, especially, since it used 3G network.
Couple years ago, when 3G was been sunset, signal got lower and lower, and the thing had even more power drain trying to get signal.
My car battery would be dead in just under 3 days from it, overnight even in the very cold winters.
I disconnected the module, since it pretty much did not even get signal anymore (and they wanted $300 +$200+ subscription a year to upgrade it to 4G module).
And now i can get 7 days before battery is weak.
Point is, even low parasitic drain is a real issue with many vehicles. A cars battery is a Starter Battery, NOT a Deep Cycle battery.
Starter Battery is meant to stay fully charged all the time, give a massive current for a very short time, to start engine, then recharge again.
Constant deep cycling of a starter battery will kill its life... i know from experience of having to replace my car battery every couple years, instead of every 5 or 6. Even killed a AGM battery in under 3 yrs.
(when i don't drive much or long work from home times)
Dodge made it so that the battery bay will only hold a certain size battery, and I have been unable to find a "bigger" one that a store has in stock, that fits both depth and width, still secure down, and allow for the air intake duct to be re-installed over top it.
Using an external battery pack to power a dash cam for extended parking use, sounds like the best idea. But, i would think the battery type would be important. One that can withstand high heat, and very cold. I live in a place that has cold winters, to Lith-ion or similar batts, refuse to work when it that cold. ( I know cause my small portable Lith Ion battery jump starter I left in the car, fully dead/no response, in the cold winter months)
