TheBlondeFella
- Dec 31, 2017
- United Kingdom
So i've finally gotten around to fitting the U1000 to replace my ageing & failing F770.
I'll be honest, the main (or really only) reason I purchased the U1000 was due to the fact that I could use the existing hard wired cables already installed for the F770 as I really didn't want to go through all that again.
I had a couple of issues installing the camera itself mainly due to the excessively wide angle of view. I wanted the camera to be as discrete as possible and therefore wanted affix it as high to the top of the windscreen and as close to the interior rear view mirror a possible. Because of the extreme wide angle lends however, this resulted I getting the base of the rear view mirror in the image. I therefore had to move the camera a lot lower and more to one side than the F770 which now means the camera footage is more offset rather than central and the camera much more 'on show'. I was (and still am) also getting a very weird dark area in the corner of the image which I can only assume is some sort of optical aberration as when I move the camera even further to one side or (and) lower is disappears. I hoped the CP filter might get rid of this but it didn't so I've removed it.
I have the flowing questions for you all.
With regards to the Cloud settings. Does my camera has to be linked to my phone for this to work and footage uploaded? If so how does the camera send me parking impact notifications when my phone is no where near the car and Dashcam?
Something tells me that I'll be asking a lot more questions about this new camera in the days / weeks to come.![Unsure :unsure: :unsure:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
Thanks in advance
- Do you use the CP filter?
- What camera setting do you all recommend?
- I have a Cellink Neo battery back up. Do I need the battery protection enabled as I have this or can it be turned off?
- My green Wifi light is continuously flashing even when driving and the phone is not connected to the camera. Is this normal?
Thanks in advance
